so i just got a nudular (or how ever you spell that) 10 bolt are the axels the same from a regular 67 8.2" 10 bolt to the 69 nod 8.2" 10 bolt i checked the splines and the legnth they are the same and fit right in, I just wanted to check and see if they will hold the same power so i can put the reg 10 bolt axels with the nid housing and not have them be weaker
I have heard the HD nodular rear's axles are heat treated for more strength.
If you are worried - go aftermarket. It would be a killer combo.
