I am trying to put a band-aid repair on my water pump until I find a new timing chain cover. I am putting it back together the same way I took it apart (I'm not too bright so I took pictures to be sure). It seems like my fan is not inside my shroud at all. It looks like if I reverse how my water pump pully is connected it will put the fan further inside the shroud. Anyone got any pix on how it should be hooked up?
