Thaks David, I'll go with that. I'l have to check out that site more. I was just reading the post about 67-68 bird and "viola" you had replied to my post. Thanks for the quick help, Pete
Put your heads on a bench upside down and make sure the upper surface is level. Fill the the chamber with a liquid. The volumn that they hold is the cc's. 1/4 cup equals 60 cc's. Tablespoon equals 15 cc's. Teaspoon equals 5 cc's. Jim
Pete, What Jim said, except that I use a piece of plexiglass (with a small hole drilled in it) and seal it down to the head with a little grease (for a more accurate reading. Surface tension of the liquid will give you incorrect readings otherwise.) Then I used an animal syringe (available at farm supply stores) to fill the chamber. Lee
