Rad hose adaptor placement
34997
10/20/05
07:45 PM
Aug 2002
toronto
32teeth
32teeth
Aug 2002
toronto
i have an autometer electric water temp guage that i plan to use
i picked up an autometer rad hose adaptor
now the question lies
do i stick it closer to the rad and run the wire along the fender
or place it closer to the gooseneck tstat housing?
any advice is more than welcome
BTW, its a 1968 OHC 1bbl engine
Re: Rad hose adaptor placement
34998
10/23/05
01:45 PM
Sep 2001
Michigan
Sep 2001
Michigan
Doesn't seem like either is a good place. Your temperature sensor would be effected by the thermostat and cooling of the hose. I would think you may get lower readings then one mounted to the engine.
1stgenbirdman
Website
0 members (), 295 guests, and 12 robots.
