I am looking into swapping a TKO into my 67 does anyone know if the z-bar and other clutch linkage pieces from a BB or SB camaro are the same Thanks Jon
Oh yah, that's nice! If you have the Chevy SB or BB the Camaro parts work. As long as you have the 1st gen Camaro mounts on your engine and it's in the position it would be in a Camaro.
Jon, No, they will NOT work. You will have to get the Firebird Z bar. The distance between the block and the frame is different which makes the Z bar different. You need a Z bar for a Pontiac block.
