On my 69 originally with a/c, I am trying to get the heating system up and running. Does anyone know where to find the heater blower motor cover for a w/ ac car? I haven't even been able to get a part number on it and mine has been broken in half by the previous owner.
Are you talking about the engine side (of the firewall) housings? If so, The side closest to the engine (the evaporator housing) is available from any of the repro houses. The other side where the blower is, is not reproduced. You will have to scour junkyards, E-pay, etc.
I have half of the outside one, the half the blower motor goes in. has a small hloe by motor that needs repaired but will not be seen when on car.I think I also have the inside section too.
That's the half that I need, the one for the blower motor. How big is the hole? Is it plastic or fiberglass construction, and would you be interested in parting with it?
I will pull it down out of the attic and take a picture for you. it is the fiberglass piece, Do you need the inside too. I have to pull my car out to get in the attic so it wont be till this weekend.. Tony
I would appreciate that. Do you remember if it attaches to the condenser case and seals to it? I am just trying to make sure that I can get all of the right parts now. What constitutes the inside part? the heater core or the a/c condenser? Thanks for looking Tony.
this is the bigger half of the evap case. there are 2 pieces total. the outside one splits into 2 pieces the one by the motor they reake thats the one I dont have. I was getting the parts for y car then ran across a hole setup. the inside piece holds the heater core. I will bring it down too
