Corrigan , you can probably see a little clip under ,its supposed to hold them on..., hold that out ,pry with screwdriver ,carefully...might want to put a triple folded rag under first!
Grab that little metal tab and yank it out. Then the arms pop off. Then you re-insert the metal tabs before you pop them back on. Believe me. The tabs pull right out. Others will disagree.
