As far as I know, the kit includes everything if you are converting from ATM and whatever you want if already a manual. Here is the link to their website.
I bought and installed the Keisler TKO600 kit. It uses a standard clutch flywheel and pressure plate. You can also use the stock pedal linkage, but you may need an adjustable clutch fork pivot ball.
The T5 is not a very strong tranny. The best ones are only capable of around 300 ft/lbs of torque in stock form. Typical Pontiac V8s produce more torque than that!
Ok.... Thanks guys... and gals! We are talking some big dollars here... I don't know that I do enough highway travel to justify this.... sure would help get to shows though.
