I know that this has been addressed in depth before and I apologize for hitting it again, but, I copied the placement template for the hood tach and now that I look at it and measure it out on my 69 ram air hood, it lines up half way on the scoop. shouldn't it just fit in the hollow area on the underside(single sheet) of the hood drivers side?
I know people said my hood tach was in the wrong spot, But they were wrong...period. That was when they were trying to cause trouble.... Take a look at the pictures on the link below, you will see that the tach fits and looks perfectly on my car. Keep in mind, 1967 hood tachs are much larger then 68 and up. In fact they actually bolt up diierently (one riffet)as well as screws and they only had one light bulb vs two on 68 and up cars. BTW, A 4" hole saw works perfectly when instaling one.
