Block casting number is located on the rear of the block, passenger side, below the cylinder head. Block casting date is found on the web below the distributor.
Thanks, there is no letter that i can see.Is the VIN anywhere else? Body styles? Assembly lines or Plants? Bye the way,I checked out your ride"over there" its most defintatly off the leash!!! My birds a yellow ragtop also, but next too yours its more Yaller!! -MIK
That is the only VIN stamp on the block. You already know it's from a Firebird, and there is not enough data on the block stamp to tell coupe or convertible. The letter will be between the 2(Pontiac)9(1969) and the 104212(partial VIN). Yes, the missing letter will tell you which plant, and will narrow to two VINs. If you want to try to match the engine back to its original car, it might be possible with a bit of work, IF the car has ever had PHS documents pulled.
