Is the wiring harness going from the dash to the center connsole between the seats suppose to be routed under the carpet & then up through the the carpet into the console or above the carpet entirely.
Marlin
1967 400/400 Conv. 2002 Trans Am Ram Air 6 Speed Hurst
Hansi is on the mark again! Yes, under the carpet from the heater area, up through the shifter hole in the carpet, and then the rear console light just runs above the carpet, but hidden under the console to the rear light below the rear ashtray.
As a matter of fact mine has 4 wiring clips under the screw heads that hold the chrome trim to the main console body (driver side) that the rear light wiring goes to.
Marlin
