Well, last night, I was hit by some gas thieves. This problem will no doubt only get worse as gas prices go up this summer. Unfortunately, the 'bird has to sleep out of doors :-(
Does anyone have a way to lock the gas door (it's a 68 'bird) closed without damaging the outside of the door? I was thinking of have a ring braised onto the inside of the door and drilling a hole through the body panel into the trunk, putting a hook by wire through the hole and attaching it to the ring on the door. You'd have to open the trunk to release the hook. Sounds like a real Rube Goldberg answer to a small problem.
I've tried to get a locking gas cap that will fit, but nothing I've found will.
Yes, I've tried the locking caps. Nothing is small enough to fit into the tight hole that the cap goes into. I think my 'bird may have a problem with how the gas filler tube is installed and I'm looking at that, since the space is so tight, but in the interim, I'm looking for alternatives.
I was gonna suggest what Brett said( he always beats me to the punch :p ), you can try something like this Ebay , have the Smith & Wesson loaded and get r dun
Then the *%*%$)&^^%### thieves will be able to see really well when they siphon the gas, but it would make it easier to get a bead on them with the Smith & Wesson.
Lights are good, so is the dog, thieves like easy targets. My home is surrounded by motion activated flood lights, dual lamps at each position. You can't approach my home from any direction without setting them off.
A "smile you are on camera" sign might help too. Then just be on the lookout for anyone wearing a Richard Nixon mask.
Years ago there you could buy a coil spring that could be inserted into the filler neck. It would prevent the siphon hose from going into the tank. I'm not sure if you can still get them. It is a conical-shaped spring.
I have motion detector lights and one night some thieves tried to walk in to my carport, set the light off and they ran so fast they tripped over my woodpile and made a mess of it (and hopefully themselves). It worked great!
You can also buy thise fake surveillance cameras(I have one by the front door along with a home made set of security stickers) and to date have had no further problems (touch wood).
I like the idea of a simple mechanism triggered from inside the trunk. Makes sense and could be easily manufactured. But, if the thief has a crowbar or large screwdriver you'll lose the gas AND the gas door.
Motion lights and a garage are my answer. In the 70's my Dad left empty shotgun shell boxes scattered around our carport and hung a few Warning signs.
Jeez! Gone for a day and a whole lot of ideas! I like the trunk monkey best (don't remember the commmercial, but if you haven't seen it, it's a riot!), but the empty shotgun shells sound good too.
Seriously, I actually found a locking gas cap that kind of fits, the door won't close, but right now, it hangs open anyway. If I take the bird emblem off the door, I think it would close.
Amervo--I live in a good neighborhood too. Thing is that with gas going up and up, I think that people who don't have a lot of money will be theiving gas more often then we've seen in a long time.
I think we're only going to be in this house for a few more years, and we'll be looking for one with a 3-car garage!
Unfortunately, I'm getting more and more worried about security as I put more money into the car :-(
Along with the lights, how about a note inside the filler door, that says, If I catch you, you will be wearing a new pair of perfect fitting cement shoes for your swim in _____ (insert nearest river)!
I guess I'm a bit more evil than most. I'd rather "catch 'em", using some type of wireless alarm, than scare 'em off with motion detectors lights. I do have X10 motion lights in front and back of my house and like them, but man, once you rip me off, I want some revenge
I have a car cover that as a "lock" on it. Basically, it's got a plastic-covered wire cable that slips under the middle of the car and locks. Problem is that I live in Las Vegas where winds at any time of the year can be between 20-40 mph. More than once, heck, more than a dozen times, I've found the cover wadded up on the curb away from the wind, the cable rubbing on the side of the car. I've kind of given up on it until I can figure out how to put grommets in both ends and string some cable under both front and rear bumpers to keep the darned thing on.
