Ok so Im not doing justice to what its called but I am trying to replace the chrome piece where the top meets the window and I have no clue how this thing comes off. soooooo before I break somthign I figured Id ask the experts. Thanks in advance guys and gals
'67 Convertible Bird Blocks a '70 400 w/ 3sp auto on the column Deluxe Int
Take out the screws that you can see and then it has lots of glue/sealer holding it on. You will have to get a little rough with it. I usually twist the heck out of them getting em off. No tricks, just lots of tugging.
Tech tip for getting through the glue: clamp a utility knife balde in a pair of vice grips, and use it to cut through the glue. (Safety glasses are mandatory because there is a good chance that the blade can break. They shatter when they brake. If you are matcho, don't bother. Buit leather gloves come in handy if you're the type of guy who doesn't like hacking up the hands.)
If you can weasel it inside, make a pass or two. Next gently pry up on one side and keep slicing. Soapy water/glass cleaner works well as a lubricant and will make cutting easier. Keep slicing and prying gently and you should be able to get them off without damaging them.
haha thanks guys I was gonna just try to beast it off but Ive destroyed alot of stuff doing that before lol. Ill deff be using gloves and shatterproof sunglasses. Im a macho guy I ride a harley i work construction but I like having eyes and fingers that work lol
