Checked my tyres and realised that one of the hub bolts on the front driver side has sheared off...not good. Have never had to do anything to the hub/rotor assembly so i'm not sure how to go about it. Can anyone suggest what i need to do? Hopefully I won't have to replace the entire assembly!?
Cheers
Dan
Dan
'69 350 coupe...It's still off the road and leaking...
Dan, The studs press in from the back side. You need to take a punch and punch out the stud and replace it from the back side of the rotor. It's cheap and easy!
I just replaced all mine last night, used a 2 lb hammer and gave them each about 4 good whacks and out they came. I used an old open lug nut to draw the new studs back in place. Piece of cake!
