Does anyone know if there are any other GM cars which I can get the spindles from which would lower the front of my bird about 1 1/2 to 2 inches? This way I can retain the stock springs thus not affecting spring travel. Also I would like to put front disc brakes on the car as well, so the spindles would need to be for disc brakes. Thanks for any help you can give me.
Eaton Springs in Detroit have a good selection of springs. they will custom make the springs to whatever specs you want. you can have a soft ride and still lower the car. good luck!
