#45448 06/15/06 02:29 PM
My '68 (which is still relatively new to me) was originally a 2 speed car, and has since been converted to a TH350. The floor shifter only has 5 stops - I can get to Park / Reverse / Drive / Neutral / Second, but no first.
Before I pull the console out to take a better look I thought I'd check with you guys - is this adjustable or do I need different parts for a 3speed auto?
Thanks!
Clay
Clay
68 350 Convertible
#45449 06/15/06 02:42 PM
Vikki
Restoration Gallery
http://thefirstgensite.com
#45450 06/15/06 03:13 PM
Thanks for the link Vikki, but I'm still confused as to what I need
"To convert from 2- to 3-speed requires only the materials to hook up the cable and the transmission properly. The conversion does not require a new detent, because the 2-speed and 3-speed are functionally the same (the 3-speed has an extra hard stop for second gear)."
Is a different cable needed? Everything is working right now, I just can't shift into first gear.
If the 3 speed as an extra hard stop for a second gear, doesn't that mean that I WOULD need a different detent??
Clay
68 350 Convertible
#45451 06/15/06 04:45 PM
I don't know dude but I read it that the kit comes with a new, laser cut, hardened detent????
#45452 06/15/06 05:46 PM
And FYI - the original detents are spot welded on. The replacements are held in place with bolts.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
#45453 06/15/06 07:38 PM
Clay,
I believe I still have my original 3-speed detent from when I converted my car to a 4-speed automatic kit from Shiftworks.
You are more than welcome to it for the cost of shipping. It should solve your problems.
Thomas
#45454 06/15/06 09:18 PM
Thanks Thomas - I am going to have a closer look at what I need, let me get back to you on that one!
Clay
Clay
68 350 Convertible
#45455 06/16/06 01:04 AM
P
P Offline
Were you able to get through to shiftworks and if so what news did they give you.
Pete
1968 350 Coupe, Verdoro Green
#45456 06/16/06 01:16 AM
When I did my ST-300 to TH-350 swap, I used a '69 three speed auto shifter that I bought from Terry Ritter. Even though I had the right shifter for my car, I still had to modify the shifter cable bracket that bolts to the transmission pan. I had to reposition this bracket so that I could get the lever on the side of the transmission to travel all the way from park to first.
John
