#47043 07/22/06 08:05 PM
Recently, while driving my 69 350 4 spd at higher rpms (like doing a 1/4 mile run) the motor is sputtering before I shift. This is something new, it allways gave me everything it had before with no problem. Everything under the hood is new three years ago with under 3000 miles. I suspect timing but am not sure it's at aprox 12*. Any sugestions. Thanks, Pete
#47044 07/22/06 09:10 PM
Maybe the distributor isnt advancing enough. you should check how much mechanical advance you are getting. Thats what i would think would be the culprit.
Matt
http://www.motortopia.com/garage/cars/PontiacPowered
1969 350 Firebird Convertible (The one I just finished)
1969 400 Firebird Convertible (The one Ill die before I finish)
#47045 07/22/06 11:33 PM
A
A Offline
Yep, I would focus on the distributor, advance, cap, points, or a combination. Let me guess, it has points?
#47046 07/23/06 02:14 AM
the points spring is too week or the centralfuge (i think thats what is called. they are the springs under the rotor cap) springs are too weak.
mark
#47047 07/23/06 02:17 AM
Requiescat In Pace
Requiescat In Pace
replace your ignition coil
#47048 07/23/06 02:34 PM
Coil or advance bushing.
To test, back off the timing 3 degrees. Run it. If it still has the problem at the same time, it's likely the coil. If the problem goes away or starts later, it's the distributor advance. Try a bigger advance limit bushing and reset the timing back to where you started.
Vikki
Restoration Gallery
http://thefirstgensite.com
#47049 07/23/06 02:46 PM
I would do it the other way around. Do your normal ignition re-new before messing with the timing. Less chance of getting in deeper. You may have a simple problem involving the plugs, wires, distributor tune up parts, ect.
#47050 07/23/06 02:54 PM
I`d check spark plugs and wires first....maybe invest in a new set...
#47051 07/24/06 02:03 AM
Does it clear up right away after you let off or does it take a minute before it begins to run normally again?
My stock lifters used to float at upper rpms and it would take a minute to clear up. Installed a set of Rhoads. Problem solved.
Robert
#47052 07/24/06 02:44 AM
Points...
