I have it committed to memory. The wire from the horn switch goes down the column and then out to the horn sending unit. It provides a ground to the relay in the sending unit. When the unit gets a ground it provides power to the wire that goes out to the horns. I believe the sending wire is blue and the power horn wire is black. I see now, after looking at the schemo, that both wires are black. One of us is wrong!
