I have a 68 firebird..was originaly a 350 was changed to a 400. the numbers stamped on the block are 400 GM-5 DN Anyone know where I can trace them? find out what year make etc. it came form? Thanks
Eric, are these number on the passenger side of the block just below the Head? Next to the waterpump housing? That is where you should find usually a two letter block code like YT or YZ etc... Then you can go to Classical Pontiac (http://www.pontiaconline.com/) and at the bottom right click restoration, then got to engine code data base... follow the instructions or leave all fields blank except for the engine code or "400" and click search... this will give you all the possible matches with year, HP, compression etc... This will give you lots of info to go from... But first you'll have to make sure you have the right numbers from the block.
Eric, when I looked for/found my no`s , they were right there under the head , next to water pump on pass. side , and were hard to see , just stamped into block , prob. 1/8" ( or less) tall or so , mine was C103858 and YX , if this is any help. This is actually from a 73 motor, which mine was traded to by prev. owner. Also I never saw any no`s like the ones you describe 400GM-5 DN on mine , where were those? Bjorn
now..your engine is a 1971 v8 400 2-BBL with an automatic trans... Now..why cant mine be that simple!!!
there is a 400 casted under the engine on both sides....the GM-5 D-N is on the passenger side under the head.... then I found the serial number casted under the water pump on the block... but those numbers are so far meaning less to me....I need the two letter code....and im beggining to think it jumped off just to mess with me!!
Eric,how many motor mount holes per side are there?In years 70-76 all blocks were recast with 5 motor mount holes per side for possible mounting in firebirds.The book you need to get is PONTIAC musclecar performance 1955-1979 written by PETE McCARTHY this is a pontiac engine bible.
after much research and visiting many web sites and through alot of help from the people on this site and others..I have found out 1) there are many sources to check with, and almost none of them have complete information. Almost every where I checked there were more and more possibilities. So dont give up if you dont see your engine in a certain book or source.
I have however managed to figure it out. I believe it is a 1977. Once again I want to thank every one for there help...Its great to have people that share simular passions to help advise you. The things I have learned allready in a short time are extremly valuable. I hope that at some point I can begine to contribute and help others with what I am learning..... BTW can we get spell check on this site? lol
