I've got a convertible 1968 400 Ram Air, with a turbo 400 Automatic transmission. I'm running a 3:55 to 1 rear gear. When I bought the car it came with a Holley 650 Spread Bore Dbl Pumper on it(#6853). I'd like to get opinions on this carb. Is it big enough? Should I consider getting something else? Anyone else familiar with this carb???
[This message has been edited by Philly V (edited November 29, 2001).]
1968 Firebird 400 Convetible 1977 Firebird Formula
Well..........thanks. I was leaning toward an Edelbrock #1910. It's an 850 CFM Q-jet. $604.51
My 400 is not "Stock" but I'm not racing it either. I've got beefed up cam, a Performer RPM intake, and a streetfighter stall. I'm attracted to performance. I like the horses under my foot. It sounds goooood! I just can't really put the $600 down unless I get a few testamonials. I was wondering if anyone else had been thru the same dilema. Thanks for the suggestions!
Whoa!! Hold up on that Q-jet copy! There are not that wonderful. I have worked with many. This is my second attempt at a reply,,server keeps dropping me, hope this makes it through!! Stick with an OEM type Rochester or Carter built Q-jet. I build about 60-70 a year, from daily hot-rods to all out racing carburetors. If matching carb# is not a factor, I prefer to use the pre-ECM carbs with the adjustable metering rods and elec. choke. These can work fantastic with non-stock intakes and other parts. Not to mention, easy to tune and buy performance up-grade perts for,(not that much is needed). These are available to two sizes/configs. Both are suitable for mild to wild apps. with A/T or M/T usage. Feel free to E-mail ma at: speedy_87ss@yahoo.com I am new to the site here and hope to help where I can! Take care,,Jeff (speedy)
