i have a yd style engine is it a 400 or 455 since in the codes there is 69 yd 400,70 yd 400,72 yd 455,73 yd 455 can somone help me out? also l have a px turbo 400 how do you figure out what year it's from? thanks
Hey BMXer, typically if it's new enough to be a 455, on the side of the block between the oil pan and the heads, it's usually marked on the block in raised numbers "455" or "400".
But if it is perhaps a 69 block... you'll have to go by the YD code and then look at the numbers right by the Dist. Hole... there will be a set of numbers there... this will give you enough to ID the year etc...
What are you working on? I'm just up and over in Federal Way, and a member of the Western WA Firebird Club... there are lots of members that have lots of parts locally! firebirdclub.com
And were having a huge all Pontaic Show N Shine on August 18th at the Everett Mall! You can't miss that one!
thanks for the info!! bought a 68 firebird conv.and just trying to figure out the numbers?i knew the car was'nt numbers maching but did'nt know what?any idea's on trans. thanks
IF PX is trans code, YD is engine code, year of block helpful. What heads? Sounds like a big car motor..GP,Cat, Bonnie. Likely blew engine, replaced motor..I am crossing my fingers your trans is right.
Si Vis Pacem Parabellum
Thanks for reply!! head # is k218 passenger side&k238 on driver which i belive is nov 21,23,1968?and manifold #'s match 1968. talk at you later. much thanks jaime
