The accessory drive uses two gaskets. They are a standard material. The problem with these gaskets are that the accessory drive slides up/down to adjust the tension and sometimes rips the gasket. I got my gaskets from fel-pro. May have a couple extra around. Haven't looked at my OHC extra's for a while. I will try to at least find the part #'s for you.
