Anyone know what the switch/sensor is on the side of my 68's st300 2 speed. I am about to swap in a th350 and noticed a 2 spade circular plug on the side. Never was hooked up and spade is broke off and it leaks bad.
I am thinking it can be only 1 of 3 possibilities:
Back-up light switch Neutral safety switch Electric kickdown (I know Turbo 400's have these)
Neutral safety is in shifter, and backup too. They both work. (nothing is hooked up to the tranny switch). I didn't think a 2 speed would have a kickdown. Someone told me once it may have been a switch to shut off the A/C if the tranny got too hot.
Oh well, not a big deal as it will soon be swapped, but it was bugging me!
I have a 350 Automatic I recently bought. When checking the Trans I noticed what apperas to be a switch or some sort of cable connection which has been cut. At first I thought it might be the odometer cable, but that works. Couldn't find anything in the manual.
Guy I got the car from said the kick-down cable needed to be replaced. Could this be it?
350 engine or trans? Mine stock was a ST300 2spd auto with (what I found out here) is an electric kickdown switch. I am putting in a TH350 trans and it uses a cable kickdown. Got universal carb bracket at autoparts store and seen cables on eBay.
Its probably like the one I'm about to take out ST300 2 speed auto. Mine had a 2 spade plug on the side, that I've been told on here was a electric kickdown. Mine was never hooked up when I got the car and just found out it was the kickdown switch a few days ago. So maybe others can tell you how and where to hook it up. Karl
