nope. 2 bolt mains. Only RAIV had 4 bolt main caps installed. The bottom end of a Pontiac is very strong, only all-out race applications should consider 4 bolt upgrade. It's not necessary.
Agreed. Some 400 blocks came drilled for 4 bolt mains but actually were built with the two bolt main caps. The testing results came back that the 4 bolt caps were not needed after some of the assembly lines had already set up and drilled the blocks for four bolts.
