Hi YA is a code for the motor it could be from 72,73 if it's a 455.But you need the codes buy the dist. and behind pass. side head on block. Hope this helps.
Jamie is right, well YA could actually be 70 - 73 HP CI Trans code Comp cam hds crb yr 360 455 A YA 10.25 67 64 4 70 280 455 A YG,YA 8.1 66 98 4 71 250 455 A YA 8.1 67 7M5 4 72 250 455 A YA,XL 8 67 4X 4 73
All in all a good motor, that could be built in any way depending on the heads etc...
