If you have the original you cantake the casing apart and rebuild it. Mine had the plunger broken off so I took it apart cleaned it up replaced the spring and used the top of the plunger from a GMC brake switch and doweld tom the bottom of the original. As far as finding one used , your going to have tough time. I saw one on ebay about a year ago and it sold big $$
