Can anyone help me with some dipstick info? I just installed a universal case TH350 in my 68' Firebird and am having problems getting the dipstick tube I bought to fit all of the way into the trans case. The problem appears to be a tight fit both in the trans case hole and the way it is bent to clear the bell housing and firewall. Does a guy have to use a Pontiac dipstick tube or are all TH350 tubes the same?
i would install an origional if the universal dont fit.i have a good used origional out of a 69 if you need one.you can contact me directly at ,,youjincho@prodigy.net
