Hi all: Need some help. Trying to install new fuel lines. I got them where they should go, I think. Having trouble from where they (2 lines) comeup thru or around the front frame, beneath the engine, and up to the fuel pump. Close but not sure. The books I have dont show how/where they attached with the correct clips.
Undercarriage pictures of a restored car may be my only solution.
if you've yet to solve this problem, i can send you some pics of the routing on my firebird (69 400) which is stock. i just took the engine out, tho, so you might need to figure out which lines connect where on the fuel pump :rolleyes:
Hot rodding, whether virtual or real... is a religion. Once the Holy Spirit of Horsepower infects you, you will see true Nirvana. And it shall be fueled by nitro-methane.
