Does anyone make a subframe connector for a 69 Bird conv. that doesn't require modification to either the connector or the car?
We are trying to install EOM 1/4 panels but the fit is poor so I need to tweek the car to make them fit and once they fit we'll install subframe connectors to keep the door gaps correct.
Brett (1stgenbirdman) designed and built a set of convertible subframe connectors for his '67. He should have chimed in here by now. I'll bet he took the day off today.
Thanks Q, yes, I took the whole week off... will be back at work on Tuesday, and can send some pix then. I can also take mesurements and send you at some point in the near future.
