#88910 05/09/07 10:39 PM
When YOU really wanna be Mean and Nasty!
Requiescat In Pace
Requiescat In Pace
is that all?a 463.damm you need at least a 1000 cubic inch engine
IS that a Holley, or Demon? If Demon; what type, and how do you like it? I'm considering a 750 Speed Demon, but don't know anyone who is running one.
Rommel its a Demon. 850 speed demon Ive had nothing but good luck with it. Got it used. The guy I got it from loved it at the track but hated it on the street. Couldn't get it to idel. Terry do you have one of those motors hiding out back?? smile
I see you are on the bottle now. Are you going to use it? Some guys hook it up for looks. laugh
YES. No HELL YES
The idle was what I was curious about. Have you had it on the street? Mine will mostly be street, but will have some strip use. I'm leaning towards an Edelbrock 800 AVS for the street, and my Edelbrock 850 QJet for the strip.
Very nice motor...forgot to say that in my last thread.
Rommel. This is a street car that goes to the track. The idel is set at 900 rpm. Idel is exellent. Ive played alot with jets and squirters.
Cool, um I mean HOT!
So far several builders are trying to talk me into loosing the dual quads and going to the Demon of BG carb on my 428 build up.
Got to admit, it looks [censored] impressive but I'd miss my quads when I pop the hood.
You don't have that stack sitting under a stock ht hood do you?
Wow, except for the chrome vlv cvrs/rad hose, and blue wires, that's the twin to my setup.
Even the engine color.
Needless to say...i like it.
My car hates me...
Q&A time.
What cam? I have a Crower RAIV w/1.72 H.S. rkrs. Thinking of going to a 245* cam.
The 4 corner idle screws are nice, arnt they.
How much you gon'a hit it with? Concerned about going over 175 with the rpm intake(even distribution).
Lowered center divider? How much, bout an 1"? Havent touched mine...yet.
My car hates me...
Comp Cams 240/246 110 lobe sep. 507/510 lift. With 1.65 roller tips.4 corner idel is a big help I think. Just hitting it with a 100 shot. That way I dont have to worry about my street tune. Ask away. smile
WICKED POWER PLANT!!
Rommel, I tried the 750 speed demon. It idled but, not as well as the E-brock 750. I also lost bottom end, but seemed to gain some at higher rpm. I didn't experiment with the jets, yet. Also, had a bit of trouble with the throttle linkage and cable. The pedal is VERY high with the Demon carb.
I put the E-brock back on.
Post a photo of the other side showing you throttle cable/linkage...please.
nice...my friend has a 750demon. says there underated its more like a 825cfm. nice carb but needs tuning. edelbrocks are pretty much set up. plus way smother.
ditch the 463stickers and put some 400's on. and when u beat them tell them its stock inside except you indexed the plugs,and balanced the sparkplug wires.
john v.
240/246...close to what i was look'n at. Thanks.
I have a msd digital 6-plus ignition module.
Has 2 seperate adjustable timing controls.
1 for N.A., and another to retard timing when the n2o solenoid is activated.
Way cool
My car hates me...
Oh ya, what fuel pressure to carb and nitrous(fuel) solenoid?
Right now, i have 6.5 to carb, and 7 to solenoid.
What plugs you run'n?
So far, i've have nkg r5671a-8(n.a) and 9's for n2o.
Want to try autolites, but not sure heat range for n2o.
My car hates me...
NGKs FR5s or 7373. Pressure 7#s both side. Heres the throttle.
Thanks 4 the photo. You have enough length in the cable to fully open the primaries?
The throttle pedal bottoms out on the floor. That why I put the pedal in a vice and bend the pedal up at the cross bar. Now I have WOT. Need a pic?
you know it...
Can't wait to see some time slips from tomorrow. Living through you now Bill! Not as exciting as doing it yourself but much cheaper. LOL
I know this looks hooky. No Poop. I add the upper arm and the gusset for strenth. After a few years of SMASHING the pedal to the floor. It might have bent back a little. But know I have WOT.Bend in vice at arrow.
Lead foot syndrome..... laugh
Thanks for the detailed illustration. Talk about heavy duty!!
...and great use of available material for "arrow".
Next he will be using smoke signals.... laugh
I took a different approach.(though, I like yours better). I trimmed away part of the cable housing that extends through the firewall. This gave the cable another inch or so of distance. I also added an extension to the throttle bracket on the carb so that the cable attched well forward of the original mounting spot. This took up the extra distance I gained in the cable. This gave me just enough motion to fully open the carb. BUT, my accelerator pedal is as high as my brake pedal!!!
Stick and stones will. smile I like smoke signals smile
Was that picture taken on your L.R. carpet? heheheee
My car hates me...
VERY nice!
