Can anyone with a 68 4 speed post a photo of the linkage setup from the switch to the reverse shift linkage. I'm missing the little wire connection. Its the barrel shaped switch as I believe there are two types.
Thanks, but I have the different switch...rather than a push style switch it is a rocker style, that needs a linkage style connection to the reverse lever.
