I am in the process of replacing the original wiring harness in a 68 Convertible which I purchased. I ordered one that matches exactly, however not all the wiring was hooked up when I purchased the car and I'm unsure where several of the wires attach. In Particular, I have 2 orange/black wires coming thru the firewall by the fue box. It looks like they may attach to the top of the accelerator pedal? Also I have what appears to be a 12 gauge red wire that has a single black clip on it that seems to coinside with the wiring for the power top? All the wires to the convt. top switch appear to be connected. Where does that one go? I have an orange/white wire with a black clip (2 prong ) that comes out of the fuse box and extends no further than the speedometer. This must attach in the general area? Lastly, I have a single yellow wire with a single black clip that extends to about the radio. Does this connect to the radio? Any expertise would be greatly appreciated. Thx
Try emailing Gerrit at grit@rgp.nl , he has a 68 wiring diagram....(tell him Bjorn told you to contact him). He should be able to send you the info. think its a web site w colored diagram, if I remember right
