I added a oil pressure, volts and water temp gauges to my 68 firebird. I tapped into the lighting circuit for the shift indicator bulb to power the gauge lighting because it was the most convenient. I just discovered by looking at the electrical schematic (again) that the shift indicator bulb is not in the dimmer (rheostat) circuit. Unfortunately, I cannot tell easily what the two wires I need to tap into for the rheo circuit are. Can someone let me know the color of the two wires I need to splice into in either the column connector or the connector in the back of the gauge pack? Thanks
I believe the orange wire is a dimmer. It goes to the dome and courtesy lights. You should see one under the dash. I believe you need the orange and the white.
