Can I swap from 14X6 Rally wheels to a 15X7 Rally wheels from a '70s Trans Am? The wheel looks the same, but is rubbing an issue? Do they look too tall on a FGF? Thanks
you should look for the other post title like yours by vikki. she has the wheel calculator on there. it'll give you an idea of what the tire size should be to make the tires the same diameter. play with the number to come up with something close to what worked for stock.
Andy
Andy, Thanks, I should have posted this in the tech area. These Rally II wheels I found are from a 74 to 81 Firebird and are nice shape. I'm sure they'll clear disc brakes but I was worried that the off-set would bring the wheel further out than the 14X6. Has any used these newer wheels on a early car?
