I think that I may have a problem with my 68 FB Conv. 400. I hope that someone on this forum may be able to help me out.
The drivers side front sits 1 inch lower than the passenger side but get this, the passenger side rear sits 1.5 inches lower than the drivers side!
The rear has multiple leaf springs and air shocks, open rear end. The crossbrace has been removed for the 2.5 " exahust. The rest of the car is stock. The shocks are fine, so is the front end, I am assuming that a rear spring sag could cause the problem but correcting that (if that is the problem) would only lower the drivers side front end more - right?
I've spent a ton on this car and it drives very well, straight and tight but I would like to remedy this asap, without having to spend big bucks (is that possible?).
If I remember right , my exhausts are 2.5 " , but no H or X crossover , just 2 straight pipes , I added back the missing X brace under , you need that , maybe thats why its twisted..? Has the car been in a wreck , ever? I suspect that first...how about door jambs , they close and fit right? But you could not just add back the brace ,need to get it straight first... I use multi leafs , std type and reg. shocks on my 69 convert.... Bjorn
Check out your subframe mounts. A bad rear one would make the car sit strangely.
