no fuel?
Re: no fuel?
FACEFIRST
171982
07/28/09
12:30 AM
Mar 2004
Michigan
Valued Mentor
Valued Mentor
Mar 2004
Michigan
Next question. When you fed fuel in from the gas can, did you run straight to the carb or through the fuel pump?
If through the fuel pump, then your fuel pump DOES work.
Find the leak in the line between the fuel pump and the tank. Air flows much easier than gas, so your pump won't pull fuel if it is pulling air.
Now that the line is full of fuel, connect it back up to the fuel pump inlet and see if fuel goes up to the carb.
Subject
Posted By
Posted
no fuel?
FACEFIRST
07/23/09
07:03 AM
Re: no fuel?
WiscBird
07/23/09
06:13 PM
Re: no fuel?
FACEFIRST
07/24/09
01:46 AM
Re: no fuel?
WiscBird
07/24/09
05:26 PM
Re: no fuel?
FACEFIRST
07/25/09
12:26 AM
Re: no fuel?
05:54 AM
Re: no fuel?
FACEFIRST
07/25/09
06:45 AM
Re: no fuel?
03:26 PM
Re: no fuel?
FACEFIRST
07/27/09
06:45 PM
Re: no fuel?
04:30 AM
Re: no fuel?
Black Bird
07/28/09
05:13 AM
1stgenbirdman
Switch to Flat Mode
Website
0 members (), 462 guests, and 18 robots.
