The exhaust system I bought from Waldron's is not fitting very well. Here is the message I sent them:
Jon,
I attempted to install the system over the weekend and I am having fitment problems.
Starting from the front, the pipes are lower than the subframe.
(Pic #1)
The right pipe doesn’t follow the transmission crossmember curve to allow it stay tucked up. It looks like if the bend in the lower part of the picture was sharper, it would allow the pipe to go under the crossmember correctly while still leaving clearance for the transmission cooler lines and vacuum hose. You can see how it forces the pipe down. Also, if it was over to left a little more it could tuck a little better while not hitting the floor. Both pipes are about ¼” away from the floor.
(Pics #2 and #3)
At the front of the left muffler, the bend right before it is angled down too much causing the muffler to also angle down, causing the front of it to hit the floor. The only way I can gain more clearance is to bend the muffler hanger inboard to move the muffler more in to the tunnel. Even then there is about ¼” floor clearance.
(Pic #4)
At the axle, both pipes are lower than the bump stops. The axle will contact the pipes first.
