Originally Posted By Bjorn Sefeldt
as this car wasnt a 400 to start with (judging from the hood), you most likely dint have 3 items that were on 400 `s and AC cars...and when you put a 455 in it those would be required
1) X filler panels
2) lower baffle
3) rubber or 'masticated' fillers on ea side of bottom of radiator
If you have those...keep looking, but if you dont have those , I bet installing those will bring you down 20-30 F....
I have already run my car with a practically brand new 455 in Oklahoma summer heat WITHOUT my original x panels, lower baffles or rubber fillers (to be installed after I get it painted) without any cooling problems whatsoever.
It's my opinion that if you have solved your cooling problem, the added benefit from those factory fixes is not all that great and should not make the difference between boiling over and not.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
'75 - 455 running hot thedad 06/21/11 03:36 AM
Re: '75 - 455 running hot ho4spdtogo 06/21/11 04:25 AM
Re: '75 - 455 running hot RLMOORE 06/21/11 05:16 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/21/11 03:28 PM
Re: '75 - 455 running hot salmon38 06/21/11 07:00 PM
Re: '75 - 455 running hot Dr. Drivability 06/21/11 07:27 PM
Re: '75 - 455 running hot thedad 06/22/11 12:41 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/21/11 07:34 PM
Re: '75 - 455 running hot salmon38 06/21/11 07:47 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/21/11 10:17 PM
Re: '75 - 455 running hot Yellowbird 06/21/11 11:56 PM
Re: '75 - 455 running hot thedad 06/22/11 12:43 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 12:53 AM
Re: '75 - 455 running hot ho4spdtogo 06/23/11 03:59 AM
Re: '75 - 455 running hot Liam68FB400 06/23/11 04:03 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 03:24 PM
Re: '75 - 455 running hot Liam68FB400 06/23/11 05:46 PM
Re: '75 - 455 running hot Dr. Drivability 06/23/11 08:29 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 08:49 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 08:51 PM
Re: '75 - 455 running hot Liam68FB400 06/23/11 09:00 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 11:08 PM
Re: '75 - 455 running hot Liam68FB400 06/23/11 09:27 PM
Re: '75 - 455 running hot salmon38 06/23/11 11:23 PM
Re: '75 - 455 running hot Liam68FB400 06/27/11 07:45 PM
Re: '75 - 455 running hot Yellowbird 06/28/11 01:33 AM
Re: '75 - 455 running hot thedad 06/22/11 12:42 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 12:50 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 12:51 AM
Re: '75 - 455 running hot thedad 06/22/11 01:04 AM
Re: '75 - 455 running hot bird67conv 06/22/11 01:11 AM
Re: '75 - 455 running hot thedad 06/22/11 03:23 AM
Re: '75 - 455 running hot Yellowbird 06/22/11 05:54 AM
Re: '75 - 455 running hot Liam68FB400 06/22/11 07:57 PM
Re: '75 - 455 running hot salmon38 06/22/11 08:11 PM
Re: '75 - 455 running hot Dr. Drivability 06/22/11 08:48 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 08:52 PM
Re: '75 - 455 running hot JCreuziger 06/30/11 03:38 PM
Re: '75 - 455 running hot Liam68FB400 06/30/11 05:04 PM
Re: '75 - 455 running hot salmon38 06/30/11 05:52 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/30/11 06:54 PM
Re: '75 - 455 running hot jose67bird 06/30/11 11:37 PM
Re: '75 - 455 running hot Yellowbird 06/22/11 01:14 AM
Re: '75 - 455 running hot thedad 06/22/11 12:40 AM
Re: '75 - 455 running hot thedad 06/22/11 12:39 AM
Re: '75 - 455 running hot thedad 06/22/11 12:38 AM
Re: '75 - 455 running hot Dcfirebottle 06/21/11 07:32 PM
Re: '75 - 455 running hot thedad 06/22/11 01:03 AM
Re: AC baffles and masticated filler panels NC68CONV 05/31/15 01:25 AM
Re: '75 - 455 running hot allen neal 05/31/15 05:59 PM
Re: '75 - 455 running hot NC68CONV 05/31/15 06:16 PM
Re: '75 - 455 running hot allen neal 05/31/15 06:48 PM
Re: '75 - 455 running hot allen neal 05/31/15 06:53 PM
Re: '75 - 455 running hot NC68CONV 05/31/15 06:59 PM
Re: '75 - 455 running hot allen neal 05/31/15 07:14 PM
