L
L Offline
Does anyone have photos of the rubber masticated fillers and lower baffles? I don't quite know what to look for.
I run hot as well. Ran hot, run hot. Had copper original style rad & clutch fan, 68 style pump & TC cover. Now on aluminum, 2 x electric fans, 69 style water pump & TC cover. All water flow thru engine area is clean. Water flow through radiator is aggressive with the 69 style pump. I definitely have the upper "x" baffles between the nose and radiator, just don't know if I am missing elsewhere.
Low temp thermostat. I don't understand the science behind getting lower temps with a higher temp thermostat...
185 at night. 220+ at red lights or 3000 rpm. 230+ with A/C and speed or traffic.
1968 Firebird 400 Convertible
Original: Engine, Intake manifold, Heads, Body, Stereo, 3.08. THM400. Engine rebuilt by Ken Keefer early 2012.
New: Holley 4bbl 670 HP, hidden iPod setup, RobbMC mini starter, A/C, front disc brakes
'75 - 455 running hot thedad 06/21/11 03:36 AM
Re: '75 - 455 running hot ho4spdtogo 06/21/11 04:25 AM
Re: '75 - 455 running hot RLMOORE 06/21/11 05:16 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/21/11 03:28 PM
Re: '75 - 455 running hot salmon38 06/21/11 07:00 PM
Re: '75 - 455 running hot Dr. Drivability 06/21/11 07:27 PM
Re: '75 - 455 running hot thedad 06/22/11 12:41 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/21/11 07:34 PM
Re: '75 - 455 running hot salmon38 06/21/11 07:47 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/21/11 10:17 PM
Re: '75 - 455 running hot Yellowbird 06/21/11 11:56 PM
Re: '75 - 455 running hot thedad 06/22/11 12:43 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 12:53 AM
Re: '75 - 455 running hot ho4spdtogo 06/23/11 03:59 AM
Re: '75 - 455 running hot Liam68FB400 06/23/11 04:03 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 03:24 PM
Re: '75 - 455 running hot Liam68FB400 06/23/11 05:46 PM
Re: '75 - 455 running hot Dr. Drivability 06/23/11 08:29 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 08:49 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 08:51 PM
Re: '75 - 455 running hot Liam68FB400 06/23/11 09:00 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/23/11 11:08 PM
Re: '75 - 455 running hot Liam68FB400 06/23/11 09:27 PM
Re: '75 - 455 running hot salmon38 06/23/11 11:23 PM
Re: '75 - 455 running hot Liam68FB400 06/27/11 07:45 PM
Re: '75 - 455 running hot Yellowbird 06/28/11 01:33 AM
Re: '75 - 455 running hot thedad 06/22/11 12:42 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 12:50 AM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 12:51 AM
Re: '75 - 455 running hot thedad 06/22/11 01:04 AM
Re: '75 - 455 running hot bird67conv 06/22/11 01:11 AM
Re: '75 - 455 running hot thedad 06/22/11 03:23 AM
Re: '75 - 455 running hot Yellowbird 06/22/11 05:54 AM
Re: '75 - 455 running hot Liam68FB400 06/22/11 07:57 PM
Re: '75 - 455 running hot salmon38 06/22/11 08:11 PM
Re: '75 - 455 running hot Dr. Drivability 06/22/11 08:48 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/22/11 08:52 PM
Re: '75 - 455 running hot JCreuziger 06/30/11 03:38 PM
Re: '75 - 455 running hot Liam68FB400 06/30/11 05:04 PM
Re: '75 - 455 running hot salmon38 06/30/11 05:52 PM
Re: '75 - 455 running hot Bjorn Sefeldt 06/30/11 06:54 PM
Re: '75 - 455 running hot jose67bird 06/30/11 11:37 PM
Re: '75 - 455 running hot Yellowbird 06/22/11 01:14 AM
Re: '75 - 455 running hot thedad 06/22/11 12:40 AM
Re: '75 - 455 running hot thedad 06/22/11 12:39 AM
Re: '75 - 455 running hot thedad 06/22/11 12:38 AM
Re: '75 - 455 running hot Dcfirebottle 06/21/11 07:32 PM
Re: '75 - 455 running hot thedad 06/22/11 01:03 AM
Re: AC baffles and masticated filler panels NC68CONV 05/31/15 01:25 AM
Re: '75 - 455 running hot allen neal 05/31/15 05:59 PM
Re: '75 - 455 running hot NC68CONV 05/31/15 06:16 PM
Re: '75 - 455 running hot allen neal 05/31/15 06:48 PM
Re: '75 - 455 running hot allen neal 05/31/15 06:53 PM
Re: '75 - 455 running hot NC68CONV 05/31/15 06:59 PM
Re: '75 - 455 running hot allen neal 05/31/15 07:14 PM
0 members (), 1,658 guests, and 127 robots.
