Posts: 68 |
The car started without problems when I first purchased it, it had a HEI distributor. The original wiring harness was hacked up pretty bad so I replaced it with a reproduction harness from NPD along with putting the MSD system in (6AL box, billet distributor, & MSD coil). I ran the testing procedure from the MSD website showing to short the violet/green wires & watch for a spark from the coil wire...there was spark so the 6AL box is working. I called MSD this evening & the tech guy thinks its the magnetic pickup inside the distributor so their sending a replacement out. Hopefully this does the trick, I'll keep you guys posted.
Anyone with a MSD ignition,..got a setup problem
boomstick
07/27/11 06:53 AM
Re: Anyone with a MSD ignition,..got a setup problem
frankyboy428
07/27/11 01:56 PM
freebird67
07/27/11 07:48 PM
boomstick
07/28/11 05:20 AM
danswrld
07/28/11 06:25 AM
boomstick
07/29/11 06:29 AM
danswrld
07/30/11 07:48 AM
boomstick
08/01/11 05:58 AM
08/01/11 06:23 AM
RLMOORE
08/01/11 04:55 PM
0 members (),
1,607
guests, and
119
robots. |
Admin,
Global Mod,
