S Offline
Originally Posted By fgr68bird
I'm having similar high temp issues. I am running 68 w/ 350. Radiator shop shows my radiator as correct, flushed radiator and still pushing 210 - 240 degrees.
Any other areas I should be looking at? Any possibility that there might be a problem with motor?
When engine was rebuilt, evidently they forgot it was a 350 Pontiac and put it back together as a Chevy, forgot to put in the oil plug at rear of motor. I installed plug and got oil pumping to the lifters.
Is there another area I might check out?
Did you do all the other things I did? filler panels etc? the biggest seems to be getting the Fan shroud. Or go with electric fans which "knock on wood" seem to be helping me at idle.
At a Loss... Cooling Issues Salesguy01 08/24/14 01:52 AM
Re: At a Loss... Cooling Issues Banshee 08/24/14 02:32 AM
Re: At a Loss... Cooling Issues Gus68 08/24/14 03:17 AM
Re: At a Loss... Cooling Issues Banshee 08/24/14 05:51 AM
Re: At a Loss... Cooling Issues Gus68 08/24/14 09:32 PM
Re: At a Loss... Cooling Issues Banshee 08/25/14 03:11 AM
Re: At a Loss... Cooling Issues Gus68 08/24/14 03:15 AM
Re: At a Loss... Cooling Issues salmon38 08/24/14 04:52 AM
Re: At a Loss... Cooling Issues Salesguy01 08/24/14 04:57 AM
Re: At a Loss... Cooling Issues salmon38 08/24/14 05:01 AM
Re: At a Loss... Cooling Issues Gus68 08/24/14 09:03 PM
Re: At a Loss... Cooling Issues Dr. Drivability 08/24/14 07:07 PM
Re: At a Loss... Cooling Issues Salesguy01 08/25/14 12:47 AM
Re: At a Loss... Cooling Issues Banshee 08/25/14 03:13 AM
Re: At a Loss... Cooling Issues Bluebird428 08/25/14 07:28 AM
Re: At a Loss... Cooling Issues Neill 08/25/14 07:53 AM
Re: At a Loss... Cooling Issues Bronze Bird 08/25/14 06:34 PM
Re: At a Loss... Cooling Issues fgr68bird 08/25/14 09:19 PM
Re: At a Loss... Cooling Issues Salesguy01 08/26/14 05:48 AM
Re: At a Loss... Cooling Issues fgr68bird 06/12/15 10:43 PM
Re: At a Loss... Cooling Issues oldskool 06/13/15 12:10 AM
Re: At a Loss... Cooling Issues Salesguy01 08/26/14 05:44 AM
Re: At a Loss... Cooling Issues Bluebird428 08/26/14 04:30 PM
Re: At a Loss... Cooling Issues Bluebird428 08/27/14 05:48 AM
Re: At a Loss... Cooling Issues Salesguy01 08/27/14 06:21 AM
Re: At a Loss... Cooling Issues Bluebird428 08/27/14 05:58 PM
Re: At a Loss... Cooling Issues Salesguy01 08/27/14 07:01 PM
Re: At a Loss... Cooling Issues Pete67400 08/27/14 07:54 PM
Re: At a Loss... Cooling Issues Salesguy01 08/27/14 08:20 PM
Re: At a Loss... Cooling Issues OE Espo 08/27/14 08:54 PM
Re: At a Loss... Cooling Issues Bronze Bird 08/27/14 09:08 PM
Re: At a Loss... Cooling Issues Salesguy01 08/28/14 04:17 AM
Re: At a Loss... Cooling Issues bigchief 06/13/15 04:58 AM
Re: At a Loss... Cooling Issues joedirt216 06/22/15 10:07 PM
Re: At a Loss... Cooling Issues salmon38 06/13/15 05:44 PM
Re: At a Loss... Cooling Issues bigchief 06/23/15 01:59 AM
Re: At a Loss... Cooling Issues joedirt216 06/23/15 08:55 PM
Re: At a Loss... Cooling Issues rohrt 06/24/15 11:49 PM
