The shop did give it a good try and cover the cable with the plastic split loom cover. It just doesn't look "natural" in the engine compartment.
I've gotten the additional cable and will re-route along(under/inside) the radiator support where the factory wires run. I'll hide the fuse under or behind the battery before it enters the rad. support. On the other end, I'll solder and heat shrink the splice.
