Orange looks like orange hi heat sealer from the rocker cover gasket? Or the valve guide seal.
The metal parts on the bottom look like broken pieces of spring or spring seat.
I'd pull the head, may be damage in there you cannot see otherwise. You may be able to get away with the rope in the spark plug hole trick and a valve spring compressor that pivots on the rocker stud.
Al
sudden loss of compression in cylinder #2, potential valve issue ahs 07/24/18 05:36 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Dr. Drivability 07/24/18 06:20 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bartbird 07/24/18 06:47 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 07/24/18 06:57 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Region Warrior 07/24/18 09:32 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bluebird428 07/25/18 03:14 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 07/26/18 05:23 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bronze Bird 07/26/18 07:28 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 07/27/18 12:02 AM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 10/08/18 08:29 AM
Re: sudden loss of compression in cylinder #2, potential valve issue Bluebird428 07/25/18 03:25 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bronze Bird 07/25/18 05:01 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bronze Bird 07/27/18 03:40 PM
Re: sudden loss of compression in cylinder #2, potential valve issue salmon38 07/27/18 04:23 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 09/02/18 03:39 AM
Re: sudden loss of compression in cylinder #2, potential valve issue Gus68 09/02/18 01:23 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 09/02/18 05:21 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Gus68 09/04/18 07:56 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Neill 09/03/18 01:44 AM
Re: sudden loss of compression in cylinder #2, potential valve issue Bluebird428 10/08/18 02:17 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 10/29/18 06:01 PM
