Dropping a cast iron cylinder head on a fender will definitely ruin your day.
Picking up freshly machined cast iron heads in your Mom's car (cause yours is not running), then stacking them in the trunk such that hanging a left turn puts one of them into a 1/4 panel - will put you in a big world of hurt (I was 18 at the time). cry
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
sudden loss of compression in cylinder #2, potential valve issue ahs 07/24/18 05:36 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Dr. Drivability 07/24/18 06:20 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bartbird 07/24/18 06:47 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 07/24/18 06:57 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Region Warrior 07/24/18 09:32 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bluebird428 07/25/18 03:14 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 07/26/18 05:23 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bronze Bird 07/26/18 07:28 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 07/27/18 12:02 AM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 10/08/18 08:29 AM
Re: sudden loss of compression in cylinder #2, potential valve issue Bluebird428 07/25/18 03:25 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bronze Bird 07/25/18 05:01 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Bronze Bird 07/27/18 03:40 PM
Re: sudden loss of compression in cylinder #2, potential valve issue salmon38 07/27/18 04:23 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 09/02/18 03:39 AM
Re: sudden loss of compression in cylinder #2, potential valve issue Gus68 09/02/18 01:23 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 09/02/18 05:21 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Gus68 09/04/18 07:56 PM
Re: sudden loss of compression in cylinder #2, potential valve issue Neill 09/03/18 01:44 AM
Re: sudden loss of compression in cylinder #2, potential valve issue Bluebird428 10/08/18 02:17 PM
Re: sudden loss of compression in cylinder #2, potential valve issue ahs 10/29/18 06:01 PM
0 members (), 1,187 guests, and 208 robots.
