Published HP spec changed to net hp for '72. There is no direct comparison between gross and net HP. Ignore those numbers if the engine was rebuilt, as carb, intake, exhaust, heads, cam and compression all factor in.
Check your math, 75-80cc will yield higher compression than you may wish for a pump gas 400. Don't forget to account for overbore.
