I have to replace this on my 69 and called Camaro Concepts in Houston about one. They have the new coupler, but the guy told me that if it is just the rag joint, I could pick one up anywhere. I found a "universal" one at the local O'Reilys and bought it. Unfortunately, the holes in the disk do not line up with the pins on the coupler (the part attached to the power steering pump.) The one I got is 2 5/8" diameter. Is that correct? And it only came with two pins, threaded on one end. I can't figure this thing out. The pins that are holding the remnants of the old rag joint in there do not look like they are coming out either. What is the deal?
