Wasn't that a Camaro only feature? Or is it a Deluxe Interior feature?
I have never been able to find evidence of these clips on my pretty original June built '67.
There are many past threads on this issue. If I say they were never a 67 bird option, 8Point will come to my house and kick my butt. Some say they were an option, some say they were a dealer install. I put mine on with screws at a location where the belts can reach when adjusted for me. The place where they are found "originally" is pretty far forward so I think you have to run the belt out to reach.
Yes, I'm experiencing major deja vu, especially seeing your pic for the 10th time. What I can't find is a template someone posted quite a while back. I thought I saved it, but if I did it's long gone.
John, Bob is right . The best way is to get your belt adjusted for your size and put the clip where the belt extends to . The original location is way to far forward to be practical. You have to adjust it each time you get in or out And like Bob S if you get thicker in the future it wont matter!!!!
You guys are right. I went out to the garage this morning with my template and saw that the clip is set for someone with very short legs and a large stomach. If I install them, I'll move them back at least two inches.
So how do they attach? Is there a nut on the back?
I guess you could use a nut. I just screwed into the plastic and the clips are on there securly. If you're being a stickler for originality, someone with original clips will have to chime in on how they mount.
