Hi Geoff,
This is the returned message (minus that actual post content.)
Return-Path: <>
To:
[email protected]From: Mail Administrator
[email protected]Reply-To: <
[email protected]>
Subject: Mail System Error - Returned Mail
Date: Sat, 24 Nov 2007 09:56:59 -0500
Message-ID: <20071124145659.HIZV2913.que02.charter.net@que02>
MIME-Version: 1.0
Content-Type: multipart/report;
report-type=delivery-status;
Boundary="===========================_ _= 7754211(2913)1195916219"
This Message was undeliverable due to the following reason:
Your message was not delivered because the destination computer was
not found. Carefully check that it was spelled correctly and try
sending it again if there were any mistakes.
It is also possible that a network problem caused this situation,
so if you are sure the address is correct you might want to try to
send it again. If the problem continues, contact your friendly
system administrator.
The following recipients did not receive this message:
[email protected]>
Please reply to
[email protected]if you feel this message to be in error.
Reporting-MTA: dns; que02.charter.net
Arrival-Date: Sat, 24 Nov 2007 09:17:50 -0500
Received-From-MTA: dns; aarprv04.charter.net (10.20.200.74)
Final-Recipient: RFC822; <
[email protected]>
Action: failed
Status: 5.2.0
Remote-MTA: dns; oakmediacreations.com
Diagnostic-Code: smtp; 450 <
[email protected]>: Recipient address rejected: Please try again in 30 minutes
Received: from aarprv04.charter.net ([10.20.200.74]) by mtai04.charter.net
(InterMail vM.7.08.02.00 201-2186-121-20061213) with ESMTP
id <
[email protected]>
for <
[email protected]>;
Received: from lees.charter.net ([68.114.250.5]) by aarprv04.charter.net
with ESMTP
id <
[email protected]>
for <
[email protected]>;
X-Mailer: QUALCOMM Windows Eudora Version 7.1.0.9
Date: Sat, 24 Nov 2007 08:17:46 -0600
To: "First Generation Firebird-L" <
[email protected]>
[email protected]>
Subject: Re: [FGF] Hot Start Issues
In-Reply-To: <
[email protected]>
References: <
[email protected]>
Mime-Version: 1.0
Content-Type: text/plain; charset="us-ascii"; format=flowed
Message-Id: <
[email protected]>
X-Chzlrs: 0
<snip>
