#25843 02/17/05 10:08 PM
What is the purpose of joining the exhaust pipes on a dual exhaust system?
Requiescat In Pace
Requiescat In Pace
on fords it serves the purpose of equealing out the back pressure between the left and right bank on the cylinders.it is not necessary on most gm engines cause the exaust is equealised through the intake manifold.if you are running a stock set up with no major mods,it does very little on pontiac engines.
Unless of course you decide to veer away from a completely stock engine. In which case there generally is no heat crossover in the intake manifold (Edelbrock Performer aluminum intake is an example). The crossover would be beneficial for this purpose. It also helps with resonance in the exhaust system. The downside is that if the "X" is welded in and you need to remove the tranny it will generally require you to cut the "X" out.
GJ
68 350 (now 474ci) Coupe
https://photos.app.goo.gl/Xk5RdwNYt1vV7Cm86
I have the Pypes (Performance Years) 2 1/2" x-pipe mandrel bent system in my 69 conv with headers. Can you say mechanical music? I don't know the exhaust flow mechanics but it sounds sooooo nice.
N
N Offline
According to Jim Hand (Early Pontiac Hero and all-round Firebird smartguy) the X-pipe greatly decreases back pressure and helps exhaust flow like nothing else can.
let me get this straight, so its better for pontiac and gm engines not to have an x-pipe then? or will it still give a little more low-end torque?
So many rides, so little time
Back pressure on 3" exhaust? How can that be? Pypes is making a killing
The Edelbrock Performer manifold does too have a crossover.
I
I Offline
Terry is blowin' smoke up your... smile X and H pipes help balance the exhaust pulses with any twin bank motor.
Tom
'69 Firebird 400 4spd conv
I had my exhaust 'custom built' ,and added an H pipe ,not an X (since easier and does about the same thing), they charged $50 for that extra piece......= not much extra cost
Any v8 will have better flow, with a x-over.
While it actually also soften the sound, - it will allways make more power. -regardless backpressure or not with 2.5 inch or 3 inch.
X-over is better than H-pipes. -x-over acts like a little 'turbo' -making vacuum, everytime an exhaust pulse passes the X..-thereby sucking the exhaust out of the other bank. -this cycle is endless, -ofcause it won't make 150 horses extra, but it WILL make more horsepower even than with open headers.
-Claus
http://rides.hotrod.com/ride/1003826/clausdanger/1968/pontiac/firebird/index.html
it's NOT black.. it's Dark metallic green.. ;-)
I know someone out there made a squashed x pipe that would work without lowering the convert brace. I'd like to put it in, anyone recall who makes it?
David
68 Droptop 400 4 spd.
Claus is right, there actually have been studies.
Dave, I think Pypes has the new oval exhaust systems.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Opps - that's RARE that has the oval systems.
1980 Turbo Trans Am
I
I Offline
After my tax refund comes I'll be getting one of the RARE systems for my convertible.
Tom
E
E Offline
Same here, I am going w/ the RARE system. I am very please with their LBMs so I will go with their dual X w/transverse muffler and stock tail pipe splitters. Should be a good system and should souond good. Right now my system is a bit louder than I thought it would be. I must be getting old as there was a day when it could never be too loud. LOL
It makes the exhaust more like a 360* system.
2 pipes cross over to opposite sides.
Back in the 70's , Herb Adams designed custom 360* hedders for 70's FB's.
His tests proved they out powered any other standard hedders at all rpm's.
My car hates me...
Y
youngdw
Unregistered
youngdw
Unregistered
Y
who is "RARE"
Ram Air Restorations
RARE
1980 Turbo Trans Am
Thanks, I'm gonna get me one of those...
David
The X pipe will really change the sound of your exhaust. I have one on my car, I liked the sound at first, now Im not sure if I like the sound better with or without it. It is a unique sound, almost like an indy car.
FGF Member #8
My 1968 Firebird Page
(click here)
If the x pipe does actually quiet the exhaust down, it's a good thing I put one on. It scares me every once in a while when I'm just minding my own business driving down the street and car alarms start going off. Of course it always brings a smile when I realise why. smile
Robert
Ya, mine is a tad on the loud side as well, the wife says she can hear me coming for blocks....
David
E
E Offline
Yeah, my wife can usually hear me coming as well...
4 Offline
To really do it right, I recall RARE mentioning a 90 degree bend X over, (at the time, he showed me a 3" pipe for a drag car - 90 degree bend inlet) which allows the pipes to be properly positioned without having to drop the brace on verts. You want this as close to the front of the car as possible. The oval x over is really the best case for clearance without giving up air flow volume. I don't know if he went ahead a made them for a 2.5 system?
laugh
My car hates me...
pretty personal information... grin
E
E Offline
LOL
Alrighty then. How about them Saints?
N
N Offline
Spread the good news: ponchoshops' wife is NOT deaf!
You mean 68Firebird400?
Mine hasnt heard me last couple years wink
My car hates me...
N
N Offline
Awe hell, now two wives may want my head on a platter over this thread!
Hef Offline
Pypes did the exhaust on my 67 also. They have pics of my car up on their installation gallery site. http://www.pypesexhaust.com/gallery92.html
Everything I read simply said to clear the exhaust as quickly as possible. Letting each side flow to Two 2 1/2 pipes is a good way to do that.
That along with the RacePro Cross Muffler makes for a nice sound.
Hef
Hef
1967 Firebird 400
4 Speed M20 Trans.
Topics35,545
Posts298,892
2 members (1967maroon, Sam and Marissa), 95 guests, and 18 robots.
JFF 1
