. . . for a larger clutch ? Mine is drilled for a 10 1/2". Hoping to get 11" out of it. laugh
Q
Q Offline
Should not be a problem. Just make sure that the shop that does the work has an 11" pressure plate to use as a pattern.
McLeod makes a pressure plate that will bolt to a 10-1/2" pattern but will use an 11" disk.
Q
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">McLeod makes a pressure plate that will bolt to a 10-1/2" pattern but will use an 11" disk.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">. . . Ya I just discovered it. Isn't it actually 10.95 dia.? Borg & Beck ? I'll be calling them Monday to confirm the bolt pattern diameter for my application. smile
Q
Q Offline
Yes - that's the one. How close to 11 do you want to be? laugh
I have one of these in my GTO. It's the Borg & Beck style. A little heavy feel to it, but it holds well. For a lighter clutch pedal, the Centerfoce "Dual Friction" is the way to go. It's worth investing in a Hays flywheel. The Hays has four different bolt patterns in it, from 10.4" to 11." Problem is, the clutch/disc/flywheel are going to set you back about $500 for this set up.
Q
So will the Borg/Beck 10.95 bolt pattern match the factory Pontiac flywheel drilled for 10.5 ?
Q
Q Offline
Yes.
Q
Posts298,896
0 members (), 160 guests, and 19 robots.
JFF 1
